Current productsNews about operating and monitoring
What is the optimum operating unit for industrial users? What is happening on the market? Computer&AUTOMATION presents a selection of new products from the operating & monitoring sector as a series of pictures.
With the VisuNet GXP HMI system with the new RM Shell 4.1, Pepperl+Fuchs offers a thin client solution for applications in Zone 1/21. According to the manufacturer, the solution enables direct horizontal and vertical access to production system information. In addition to communication within the production process, access is possible across all hierarchy levels right down to the sensor. The HMI system communicates with the process control system or the MES - which can also be located in the cloud - and enables the process plant to be controlled and monitored. The VisuNet GXP can also access sensors via a web browser for commissioning, configuration or maintenance purposes. Using the mechanisms of the VisuNet Control Center, administrators should be able to connect to any smart remote monitor with RM Shell 4.1. In this way, the user can also be supported remotely - for example, to rectify faults.
