Bachmann Electronic
Flexible visualization without additional effort
M1 webMI pro from Bachmann enables access to the industrial visualization and operation via web browser directly from the 'M1' controller on the panel PC, SmartDevice or office computer.
According to the provider Bachmann, the current version 2.20 brings a number of improvements for use with location-independent operation. The graphics editor and extended prefabricated graphics objects bring more convenience to project implementation. These elements are now identical to those of the 'big sister' 'atvise scada 3.7', making it easier to switch in both directions. An extended API for control opens up access to comprehensive file and transfer functions, details on the control structure, variable and alarm information and access to the real-time data recorder. The retrofittable software process for the modular M1 automation system makes it possible to use the same visualization solution both in a higher-level atvise application and directly integrated on the M1 controller without additional engineering effort.
