Wachendorff Process Technology
Fanless Panel PC / Display series
Wachendorff Prozesstechnik presents the fanless automation solution 'Auhmi' from Aplex Technology. The series includes panel PCs (Auhmi-9) and displays (Auhmi-1), each in sizes from 10.1 to 21.5 inch TFT-LCD and IP66-certified front panel.
© Wachendorff Process Technology
The devices are powered by Intel Tiger Lake Core i3 and i5 of the 11th generation. The devices are characterized by a full-surface panel and, according to Wachendorff Prozesstechnik, an extremely slim frame made of die-cast aluminium. Special mounting elements support mounting and positioning. In addition, the absence of mounting holes on the panel frame prevents dust from getting inside. The devices have various I/O interfaces: The Auhmi-1 series includes 1x VGA, 1x HDMI, 1x DP port and OSD control. The Auhmi-9 series includes 4x USB 3.0, 2x GbE LAN, 1x COM and 1x DP/HDMI port. In addition, the panel PC also supports expansion cards, for example Mini-PCIe, COM, LAN, CAN BUS, Digital I/O, POE and USB ports.
In focus: HMI
The e-paper of issue 06/23
How can digitalization and artificial intelligence help to make production processes sustainable? How can cobots and automated guided vehicles bring variety to everyday working life and how can they support people? Starting points in this issue.
Rafi
Illuminated pushbutton with 5 V supply voltage
Rafi is now offering twelve additional versions of the 'Lumotast 16' series illuminated pushbuttons with an operating voltage of just 5 V for LED control. This makes these actuators, which are designed for standard installation openings of 16.2 mm,...
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
