Panel PCs
Quelle: Kontron | Lukas Dehling,
Equipped with IP69K protection
The Panel PC FlatClient HYG from Kontron has a maximum protection class of IP69K and was developed in accordance with the EHEDG guidelines (European Hygienic Engineering and Design Group).
© Kontron
It is therefore qualified for applications in sensitive hygienic areas and the robust basic design should also enable operation directly next to dirty production machines. All variants have a smooth, seamless display surface for easy cleaning. With IP69K protection, the new panel PC is also suitable for washdown applications, such as high-pressure cleaning. Its PCAP touch display can clearly distinguish legitimate control inputs from interference, such as the impact of water droplets or the accidental pressing of the entire palm of the hand, even when operating with gloves. Thanks to its symmetrical design, the 21-inch Full HD display can be operated in both portrait and landscape format. Display sizes from 15.6 to 23.8 inches are already planned.
Starter kit
Entry into the IoT
A starter kit from Inonet, together with a web application, is designed to pave the way for users to enter the future of the Internet of Things (IoT). The target group are users who want to monitor their environment automatically and initiate...
Software
Developing autonomous systems
MathWorks introduces the Sensor Fusion and Tracking Toolbox, available with the 2018b release. The new toolbox provides engineers with algorithms and tools to determine and maintain position, orientation and situational awareness.
Gateways
Available with Azure IoT Edge
Moxa's IIoT Edge Gateway is available with Microsoft Azure IoT Edge pre-installed. According to the manufacturer, it offers Azure users a user-friendly solution to expand their IT infrastructure and enable OT data connectivity with their industrial...
Boards
Image processing in focus
The LV-67X industrial mini-ITX board from Spectra is designed for image processing solutions. The integrated LGA1151 socket works with the latest Coffee Lake, Celeron and Pentium CPUs.
