Monitors
Quelle: Comp-Mall | Lukas Dehling,
Device depth from 40 to 50 mm
The new industrial open-frame monitors in the LCD KIT F series from Comp-Mall have a device depth of 40 to 50 mm - depending on the monitor size.
© Comp-Mall
© Comp-Mall
The display sizes available are 12.1 inches and 15, 17 and 19 inches, without a touchscreen or with resistive or P-CAP. Optical/air bonding is used for multi-touch P-CAP and the special flat resistive variant. The open-frame monitors offer a 4:3 aspect ratio, resolutions of 1024×768 (XGA) and 1280×1024 (SXGA), a brightness of 350 to 600 cd/m2, a contrast of 700:1 to 1000:1 and a high MTBF time of 50,000 hours. They each have an analog VGA and a DVI-D input and USB/RS232 interfaces are available for the touchscreens. The OSD membrane keypad is located on the rear to keep the front panel clear and uncluttered. OSD software is designed to simplify the external settings of the monitors. With an operating temperature range of -20 to +60 °C and a power supply of 12 V(DC) or an optional wide-range power supply of 9 to 36 V(DC), the devices are designed for use in industry. Thanks to the VESA standard and various installation kits, they can be mounted on the wall, in a control cabinet or in a panel.
Kontron
Managing Board expanded
Kontron expands its Management Board with Philipp Schulz and Dr. Johannes Fues. As COO, Schulz will be responsible for the Aerospace and North America business units, while Dr. Fues will assume the position of COO for the GreenTec business unit.
Kontron
Control panel series updated
Kontron has developed a new generation of its Control Panels which, thanks to the more powerful Arm NXP i.MX8M Plus processors, provide a significant performance boost compared to previous models.
