Panel PCs
Quelle: TL Electronic | Lukas Dehling,
Based on NUC technology
The 48 mm flat panel PCs in TL Electronic's Varioline series with PCAP multi-touch technology are based on Intel's latest NUC (Next Unit of Computing) technology.
© TL Electronic
The small-form-factor mainboard measuring 10.16 × 10.16 cm with the energy-saving fifth-generation Core i5 processor 5300U (Broadwell) is equipped with 4 to 16 GB of RAM and a solid-state drive from 64 GB, depending on requirements. The rear mounting interface can be snapped into the Quicklock box without any tools for mounting or removal. This is firmly connected via a VESA interface to a mounting set for stand or support arm installation, in which the cable routing for power supply, USB and Gigabit Ethernet is integrated. Users can choose between display diagonals from 38.1 cm (15 inches) to 48.3 cm (19 inches) in 4:3 format with a maximum resolution of 1280 × 1024 pixels and from 54.6 to 61 cm (21.5 to 24 inches) in full HD resolution with 1920 × 1080 pixels in 16:9 widescreen format. The devices operate without a fan and offer IP65 protection.
Kontron
Managing Board expanded
Kontron expands its Management Board with Philipp Schulz and Dr. Johannes Fues. As COO, Schulz will be responsible for the Aerospace and North America business units, while Dr. Fues will assume the position of COO for the GreenTec business unit.
Kontron
Control panel series updated
Kontron has developed a new generation of its Control Panels which, thanks to the more powerful Arm NXP i.MX8M Plus processors, provide a significant performance boost compared to previous models.
