Touch operating devices
Quelle: R. Stahl HMI Systems | Inka Krischke,
Approved for Ex zones 1 and 21
Robust touch operating devices from R. Stahl HMI Systems enable machine-oriented operation and visualization of applications in hazardous areas.
© R. Stahl HMI Systems
The ET-208 operator interfaces approved for zones 1 and 21 with a 7-inch widescreen and a hardened glass surface are protected on the front in accordance with protection class IP69. This means they meet FDA requirements for cleanroom suitability, as the front panel can be cleaned with high-pressure cleaners. The HMIs have a V2A stainless steel housing and are corrosion-resistant with certification to ISA-S71.04-1985, degree of severity G3, in accordance with EN 60068-2-6. They can also withstand seawater without any problems. They can be operated at ambient temperatures from -40 to +65 °C. A bright display and anti-reflective coating ensure good readability in outdoor use and in bright light. The HMIs have interfaces for Industrial Ethernet, RS422/RS485 and optional WLAN. The processor is the Cortex A8. As standard, the touch operating devices are set up with Windows Embedded Compact 7 as the operating system. The 'SPSPlusWIN' software can be used to create and edit screens, process connections and messages for the HMI devices.
Kontron
Managing Board expanded
Kontron expands its Management Board with Philipp Schulz and Dr. Johannes Fues. As COO, Schulz will be responsible for the Aerospace and North America business units, while Dr. Fues will assume the position of COO for the GreenTec business unit.
Kontron
Control panel series updated
Kontron has developed a new generation of its Control Panels which, thanks to the more powerful Arm NXP i.MX8M Plus processors, provide a significant performance boost compared to previous models.
