Data logger
Up to ten channels per input
With the Almemo 500 data logger, Ahlborn is launching a new device variant in the field of measurement data acquisition. It is operated via an 8-inch tablet with a pre-installed app.
In addition to visualizing the measurement data, the device and all connected sensors can also be configured on the tablet. The connection of different sensor types is made possible by galvanically isolated, independent measurement inputs, whereby existing sensors can also be connected via the Alemeo connectors. The standard version offers 20 inputs, and up to ten channels per measurement input are possible when using the new D7 sensor generation. The logger measures at a speed of up to 4000 measurements/s and is time-synchronized. The measured values are displayed as individual measured values, measured value lists, via freely configurable displays or as a line diagram. Historical measurement curves from the measured value memory can be loaded offline or while a measurement is running. The device is equipped with a 0.82-inch OLED display for visualizing system messages. The measurement data can be exported using the Wincontrol program or Excel. The device is supplied in a 63 HP and 84 HP desktop housing (stackable) or as a 19-inch rack. The internal 3 GB measured value memory is also available as a ring memory and enables up to 600 million measured values to be saved, depending on the measured value resolution.
