Labom
Two pressure transmitters at one measuring point
Labom makes individual measurement solutions possible - for example, level measurement in a container for a company in the pharmaceutical industry.
© Labom
For this level measurement, it was necessary to measure at just one measuring point with significantly varying pressures and a large temperature range. As a solution, two pressure transmitters from the 'Pascal CV3' series were used, each covering different measuring ranges and mounted together on a diaphragm seal. Depending on the time in the process and the fill level in the tank, the system can switch from a higher measuring range of up to 4 bar to a smaller measuring range of up to 400 mbar. The smaller measuring range is overload-proof and the sensor is insensitive to the higher pressures. The diaphragm seal has also been fitted with the LTC diaphragm (LTC = Low Temperature Coefficient) developed and patented by Labom. This diaphragm compensates for temperature-related volume expansions of the filling liquid with a specially shaped stainless steel diaphragm and, according to the manufacturer, increases the measuring accuracy by up to 70 % compared to conventional sinusoidal diaphragms.
Sick
Award for sustainability management
Sick has received a platinum medal in the EcoVadis sustainability ranking. This puts the provider of sensor-based automation solutions in the top 1 percent of more than 130,000 companies worldwide that have been assessed over the past twelve months.
Vega Grieshaber
Chip start-up founded
The start-up milli IC from Karlsruhe specializes in the development of ASICs - and Vega Grieshaber is 'on board' to ultimately develop radar measuring devices with radar frequencies of more than 100 GHz.
