HBM
Torque transducers for quick application tests
HBM is launching the 'T40CB' torque transducer, which is particularly suitable for testing automotive parts in confined spaces thanks to its central bore.
© HBM
According to the manufacturer, the compact model with a length of only 49 mm/ 54 mm and a central bore of 37.5 mm/ 46.5 mm diameter offers technicians the flexibility and ease of use required to perform application tests on automotive parts such as coaxial gearboxes or manual transmissions. The torque transducer uses HBM's 'T40' electronics, which offers an accuracy class of 0.05 and high linearity, ensuring accurate and reliable results. It also has analog and digital interfaces that ensure integration into many different test bench systems.
Megatron
Angle measurement in the smallest space
Thanks to their housing depth of just 6 mm and a housing diameter of 16.4 mm, the hollow-shaft conductive plastic potentiometers in the 'MHP16' series from Megatron are particularly suitable as position indicators in motor valves and actuators.
Digitization
Measuring amplifier 4.0
Accuracy class, measurement inputs and interfaces - these have been the key features of measuring amplifiers to date. In the course of Industry 4.0, others will be added, such as remote diagnostics, web interface and pre-calculation in the module.
Digitization
Strain gauge load cells on the rise
The digitalization of weighing technology can begin: Digital strain gauge-based load cells are now more robust, more durable and less expensive than their analog counterparts. In addition, analogue weighing technology can be digitized using...
