Thyracont
Preventive maintenance
The 'Smartline' vacuum transmitters from Thyracont measure in the range from low vacuum to high vacuum and support the control of industrial vacuum processes.
© Thyracont
In addition to the classic, analog 0 to 10 V output signal, digital interfaces such as RS485, Ethercat or Profinet enable connection to intelligent process control systems. Preventive maintenance via the Profinet interface enables direct integration into an existing Profinet network with a PLC, which can also take over the entire monitoring of the process. According to Thyracont, the Profinet modules are MRP-capable, have a high speed with low power consumption and can be updated. In addition to the measured values, the user can also evaluate data on sensor wear, the time of the last readjustment and the number of operating hours. This makes it easier to plan maintenance intervals, procure any necessary spare parts in good time and optimize system running times. All parameters are also available in the 'Thyracont VacuGraph' software.
Kistler
Solid sales development in 2025
The Kistler Group generated sales of 424 million Swiss francs in 2025. With a currency-adjusted decline of 1 percent, or 5 percent in Swiss francs, the company was able to keep sales stable compared to the previous year.
AMA Innovation Award 2025
Submit applications now
The AMA Association for Sensors and Measurement (AMA) is calling on scientists and developers from industry and research to apply for the AMA Innovation Award 2025. We are looking for research and development results in sensor and measurement...
Janitza
Management expanded
Axel Hessenkämper joined Janitza as the new Chief Executive Officer (CEO) on September 1, 2024 and is part of the management team alongside Mr. Janitza, Mr. Müller and Mr. Veidt.
