Inspection systems
Miriam Krechlok | Lukas Dehling,
On the trail of impurities
Glass, plastic or metal splinters: foreign bodies in food are a danger. Product inspection technology can prevent this. Manufacturers can use both metal detectors and X-ray inspection systems - or both.
© Mettler-Toledo
With the increasing complexity of production and packaging processes in the manufacture of food, the risk of product contamination by foreign bodies has also increased. After microbiological pathogens, contamination with foreign bodies such as glass, metal or plastic particles is now the second most common reason for food alerts and recalls in Europe. The European Rapid Alert System for Food and Feed (RASFF) lists 856 entries of foreign body warnings for the first quarter of 2018 alone.
The number of contaminations caused by foreign bodies has increased twelvefold across the EU compared to 1970 to 1990 and 2011 to 2014. The latest RASFF annual report states that the three most common types of foreign bodies in food are metal, plastic and glass.
Risk analysis with HACCP or HARCP audit
Thanks to rapid advances in product inspection technology, many types of foreign bodies can now be reliably detected in food production. The main question for manufacturers is whether they should install a metal detector, an X-ray inspection system or both. The easiest way to decide between metal detection and x-ray inspection is to take a close look at the application. The first step should be a HACCP (Hazard Analysis and Critical Control Points) or HARCP (Hazard Analysis and Risk-based Preventive Controls) audit.
An HACCP audit identifies contamination risks in the manufacturing process and the types of foreign bodies that can occur. Appropriate product inspection technology must be installed at the critical control points (CCPs) identified in the audit to minimize risk. A HARPC audit also covers possible contamination hazards in the manufacturing process, but also takes into account other safety-relevant factors such as visitor access and control. In any case, it is advisable to also carry out product tests to determine the most suitable technology. The international trend is for large supermarket chains to increasingly require their suppliers to comply with strict codes of practice that exceed international food safety regulations.
Foreign body detection with metal detection technology
Metal detection systems are one option for product inspection: they identify all metallic foreign bodies, including ferrous (such as chrome or steel) and non-ferrous metals (such as brass or aluminum) as well as magnetic and non-magnetic stainless steels. The systems can be installed to inspect raw materials supplied for food before processing, at numerous points in the production process and at the end of the production or packaging line. The metal detection technology is suitable for inspecting a wide range of different product types, including loose, unpackaged or pasty products, pumped products such as liquids, bulk goods, loose powders and solids in free-fall systems, as well as packaged products. It can also be used to inspect large, robust containers such as bottles, jars and composite containers. However, care must be taken to ensure that the product is checked for metallic foreign objects before any metal closures are attached.
Influence of product properties
Products with a high moisture content generate similar signals to metallic foreign objects when they pass through a metal detection system. This so-called product effect can be eliminated using software algorithms.
© Mettler-Toledo
When deciding whether metal detection technology is the method of choice, the nature of the product - in particular its dryness or conductivity - must be taken into account in addition to the manufacturing and packaging process.
As a general rule, the detection of metallic foreign bodies is relatively easy with dry products. Due to the lack of moisture content, these products are generally non-conductive and the metal detection technology achieves a very high detection accuracy even for extremely small metallic foreign bodies. The situation is different for products with a high moisture content, such as chilled and salty products and products with a high water content: these are particularly challenging for foreign object detection, as they are conductive like metal itself. When passing through the metal detection system, these products cause a disturbance in the detection field and thus generate signals similar to metallic foreign objects. This so-called product effect can be largely eliminated by using software algorithms and setting the optimum operating frequency. A high-quality metal detector can therefore be operated at different frequencies and therefore offers a sufficiently high search sensitivity for the detection of small metal contaminants, even with moist and conductive products.
Problem case metallized foil
Products in metallized film packaging can usually be reliably inspected with metal detectors in low-frequency mode. However, depending on the thickness of the film, this can lead to a reduction in the achievable detection sensitivity. In some cases, it is therefore advisable to check very thick metallized film packaging for metallic foreign bodies before packaging.
A general advantage of metal detection technology is that the system can be designed for very different product sizes. The metal detector airlocks at airports clearly show which packaging and product sizes can be detected for foreign objects using metal detection technology if required. The rule of thumb here is: the higher the opening for the product to pass through, the lower the detection sensitivity of the metal detector. However, this reduction in detection sensitivity can be largely compensated for by adjusting the distance of the coil system in the metal detector. The use of variable frequency technology, in which the most suitable frequency is automatically set for each application and therefore a variety of products with varying moisture content can be inspected, also helps to solve any problems with detection sensitivity.
The X-ray inspection technique
X-ray inspection systems are suitable for detecting foreign objects in a wide range of different product types - from pumped products such as pasty masses and liquids to semi-solid and solid products and loose bulk goods.
© Mettler-Toledo
In contrast to metal detectors, X-ray inspection technology can be used to detect other contaminants in the food in addition to metals, such as glass, stones, bones, plastics and high-density rubber compounds. The systems are suitable for a wide range of different product types - from pumped products such as pasty masses and liquids to semi-solid and solid products and loose bulk goods. They are also ideal for inspecting packaged products of all shapes and sizes, as well as products in film or metallized film packaging. Food in large, robust containers such as glass jars, bottles or metal cans can also be inspected for foreign objects using X-ray inspection systems. In addition to checking for foreign bodies, the devices allow a range of other measures to be taken to ensure the product conformity of the food. For example, a number of quality checks can be carried out simultaneously within the production line, such as determining mass, counting components, detecting missing or damaged products and packaging, monitoring fill levels and checking seals for intactness. X-ray inspection systems were first used in production lines in the late 1980s and have since been used by food manufacturers to ensure product safety and quality.
In addition to checking for foreign bodies, X-ray inspection systems enable further measures to be taken to ensure the product conformity of the food. For example, they can check the integrity of packaging.
© Mettler-Toledo
X-ray inspection systems capture a grayscale image of the product. Software compares this image with a predefined standard and decides on the basis of this comparison whether the product in question should be assessed as good or contaminated. In the event of contamination, the software sends a signal to the automatic rejection system, which removes the product from the packaging or production line. The image provided by the X-ray inspection system is based on the measured absorption differences between the product and the foreign object. Detection is usually only possible for foreign bodies that have a higher density than the product in which they are embedded. This also explains why, in applications in the food and pharmaceutical industries, potential contamination from low-density foreign bodies such as insects, wood or polyethylene film cannot usually be detected using X-ray inspection due to the differences in density between the product and the foreign body being too small.
The size of the product also plays an important role in the detection accuracy that can be achieved during X-ray inspection. For the inspection of large-sized products, the X-ray generator must be moved further away from the product so that the generated X-ray beam can cover the entire product. Increasing the distance between the generator and detector also reduces the detection sensitivity of the system.
Special challenge: aluminum
With its absolute barrier function, aluminum is one of the most important raw materials in the packaging market. Processed in weight- and material-saving composite films and flexible packaging such as stand-up pouches, but also as a proven packaging material for ready meals and frozen goods, the light metal is predicted to continue to grow in the coming years. X-ray inspection systems are the ideal choice for inspecting products packaged in aluminum foil for metallic contaminants. While metal detection systems are less sensitive to detecting foreign bodies inside these aluminum-containing packages, X-ray inspection systems can virtually see through the aluminum foil with its low density to inspect the interior for metal contaminants. If, on the other hand, potential aluminum contamination is to be expected in the product, metal detection technology is generally the better choice.
Further criteria for the choice of technology
Metal detection systems are usually the better solution for economic reasons if only the detection of metallic contaminants is required. The choice should therefore be made primarily on the basis of the potential risk of metallic versus non-metallic contaminants. If protective measures against non-metallic contaminants such as glass, stones, bones or rubber compounds and high-density plastics are required, investment in an X-ray inspection system is essential. In addition to the expected contaminants, other indicators such as line speed, space requirements, size and nature of the product to be inspected as well as the purchase and operating costs can be decisive for the selection of one or more inspection systems. Both metal detectors and X-ray inspection systems are suitable for both variable and high packaging and production line speeds. X-ray inspection systems can handle belt speeds of up to 120 meters per minute, while metal detectors are suitable for reliable contaminant detection at speeds of up to 400 meters per minute - even higher inspection speeds can be achieved for pumped liquid applications.
A metal detector at the beginning of the production line can detect large metal contaminants at an early stage before they are broken down into smaller, harder-to-detect contaminants in further production steps and can cause damage to downstream production equipment. Another metal detector with high detection sensitivity at the end of the production or packaging line can be used for final inspection to ensure foreign body-free end products. In addition, an X-ray inspection system installed at this point allows an even broader inspection for possible foreign body contamination and other quality features to ensure the packaging integrity and product conformity of the delivered products.
Author:
Miriam Krechlok is Head of Marketing at Mettler-Toledo Product Inspection Germany
