Data logger
Input range between 20 mV and 100 V
Althen offers the Graphtec GL240 midi data logger for recording voltage, temperature and pulses. According to the manufacturer, the large buttons and high-contrast TFT color display make it easy to configure the data logger.
The buttons are ergonomically arranged so that they are easy to reach and can be operated even when wearing gloves. The measuring signals are connected via the integrated M3 screw terminals. The input range for measuring voltages can be set between 20 mV and 100 V. Numerous different thermocouple types can be connected and configured in the device. The sample rate per measuring channel can be selected between 10 ms and 1 h. The individually adjustable alarm output can be used to monitor the individual measuring channels. The model also offers trigger and timer functions. Data is recorded on an SD card (standard 4 GByte, up to 32 GByte possible) or on a PC using the supplied APS software.
