Polytec
High-resolution fiber optic temperature and strain measurement
Polytec has the 'ODiSI 7000' system family in its range for the fiber optic-based measurement of temperature and strain profiles.
© Polytec
The fiber optic interrogator from US manufacturer Luna Innovations, distributed by Polytec, differs from fiber Bragg-based systems due to its high spatial resolution of <1 mm. With measuring distances of up to 50 m, up to 76,000 measuring points are available in a single standard optical fiber. The temperature measuring range extends from -40 to +300 °C; with special fibers, temperatures from the cryogenic range up to approx. +600 °C can be measured. In strain measurement, ±12,000 microstrain is possible. The measurement resolution is 0.1 °C or ±1 microstrain. The system is based on the 'ODiSI 6' series and offers, among other things, flexible expandability to up to eight channels. The readout device is designed for industrial use, has robust plug connectors and is supplied with a 50 m supply cable between the fiber sensor and interrogator. The modular design enables a high-speed option for readout rates of up to 250 Hz.
In focus: Agriculture
The e-paper of issue 05/2024
Strategies for the future are one of the topics covered in the current issue of Computer&Automation. Read about the reforms that associations are demanding from politicians, the opportunities offered by technologies such as ChatGPT and SPE and...
The "living" e-paper
Screen Edition 2024
Welcome to the first issue of the 'Screen Edition', which opens up a completely new way of reading and informing yourself: With the Screen Edition, we offer you a dynamic and always up-to-date source of information with its finger on the pulse.
AMA Innovation Award 2025
Submit applications now
The AMA Association for Sensors and Measurement (AMA) is calling on scientists and developers from industry and research to apply for the AMA Innovation Award 2025. We are looking for research and development results in sensor and measurement...
Janitza
Management expanded
Axel Hessenkämper joined Janitza as the new Chief Executive Officer (CEO) on September 1, 2024 and is part of the management team alongside Mr. Janitza, Mr. Müller and Mr. Veidt.
