Flow measurement
Balluff expands process technology division
Balluff has had thermal flow monitors in its range since November 2018 and is thus expanding its process technology division. Product Manager Julia Wick talks about the portfolio expansion.
"Our aim is to gradually expand the portfolio for small process technology," says Julia Wick, Product Manager at Balluff.
© Balluff
Ms. Wick, why is Balluff focusing on the measurand flow rate?
Julia Wick: The continuous monitoring of process media in machines and systems is ultimately important in order to avoid machine downtime and ensure process reliability. Pressure, temperature and flow sensors support this. We have already been active in this area for many years with our pressure sensor portfolio; expanding the portfolio to include flow measurement technology was therefore a logical next step.
What does the technological implementation look like?
Julia Wick: The flow monitors are suitable for water and aqueous media. Liquids containing solids, such as cooling lubricants with chips, can also be monitored. The sensors work according to the thermodynamic principle: there are two measuring points in the sensor element. The first measuring point measures the temperature of the medium, the second is heated and is a few degrees above the medium temperature. The medium flowing past dissipates heat from the heated measuring point, cooling it down. The sensor electronics evaluate the temperature difference between the two measuring points as an indicator of the flow velocity.
How do the sensors communicate?
Julia Wick: The flow monitor detects whether a preset flow value has been exceeded or not reached and outputs this information as a switching signal. Depending on the variant, there is also a display or a row of LEDs that visualize how high the current flow rate is.
What is special about the flow monitors?
Julia Wick: As there are no moving components that could fail due to corrosion or dirt, maintenance costs are reduced. The screw-in variants can be used universally for different nominal pipe diameters. However, it must be ensured that the entire sensor tip is surrounded by the medium. This allows the user to use more identical parts and save storage space. And in order to be able to monitor media in small pipe diameters, we also have inline versions in our portfolio.
Where are the sensors typically used?
Julia Wick: Depending on where the flow monitor is installed, conclusions can be drawn from the switching signal: For example, a reduction in the flow rate can indicate that a feed pump has failed, a filter is clogged or the pipe system is leaking. Continuous monitoring of the cooling lubricant flow, for example in a machining center, protects tools and workpieces and improves the process reliability of the system. The flow monitor uses the switching signal to indicate a fault in the cooling circuit so that the machining center can be switched off in good time.
What does the future roadmap look like?
Julia Wick: The thermal flow monitors are our first step within flow measurement technology, and other measuring principles will follow. Overall, the process sensor technology portfolio has already been expanded: in addition to pressure and flow measurement technology, we have recently added an initial portfolio of temperature sensors to our range.
Althen
Change in management
Althen Mess- und Sensortechnik will be managed by Edwin Goezinne in the future. He succeeds Dr. Timo Hartmann, who was at the helm of the company in Germany for six years.
CADFEM / Ansys
Test digital simulation live
On September 26 and 27, students at Amberg-Weiden University of Applied Sciences will be able to find out how computer simulation can be applied directly to research and development projects. CADFEM and Ansys invite you to the big live simulation...
