AI solutions
Siemens and Google Cloud cooperate
Google Cloud and Siemens are cooperating to optimize manufacturing processes using AI-based solutions. To this end, Siemens wants to integrate Google Cloud technology for data and artificial intelligence into its factory automation solutions.
Siemens sees itself as a leader in the further development of industrial automation and software, while Google Cloud sees itself as a leader in data analysis, AI and machine learning. The cooperation that has now been announced is intended to combine the best of both worlds and bring AI/ML to the manufacturing industry on a large scale.
© Siemens
Industrial processes are increasingly data-driven. In the manufacturing industry, older and different software applications are often used to analyze plant data. This is resource-intensive and often requires manual updates to ensure accuracy. Because AI projects are used by many companies as a "stand-alone" solution in manufacturing, manufacturers struggle to implement AI solutions on a large scale in their global operations.
By combining Google Cloud's data cloud and AI and machine learning capabilities with Siemens' factory automation portfolio, manufacturers can unify their factory data. They can also use this data to run cloud-based AI/ML models and deploy machine learning algorithms. This enables applications such as visual quality control of products or predictive maintenance of systems and production lines.
Using artificial intelligence in production facilities and integrating it into automation and their networks is a complex task that requires highly specialized expertise and innovative products such as Siemens Industrial Edge. The aim of the collaboration is to facilitate the use and scalability of AI in operations in conjunction with Industrial Edge and its management.
"The potential of artificial intelligence to radically change the manufacturing sector is far from exhausted. Many manufacturers are still stuck in AI 'pilot projects' - we want to change that," said Axel Lorenz, VP Control at Siemens Digital Industries, Factory Automation. "The combination of Google Cloud's AI/ML technology with Siemens' Industrial Edge and Industrial Operation solutions can significantly change the manufacturing industry."
Industry 4.0
The top dialog
The future-oriented Industry 4.0 project was officially launched at Hannover Messe 2011. The Industry 4.0 platform's research advisory board has now met for a top-level dialog and drafted a twelve-point communiqué on the work still to be done.
Compar
Artificial intelligence for image analysis
For soldered connections on printed circuit boards, the switch to lead-free solder causes increased failure rates. Quality control must therefore be improved. However, conventional methods with camera-supported automatic image evaluation quickly...
Deevio
End of manual visual inspection?
The widespread industrial use of artificial intelligence is still a long way off. Yet self-optimizing deep learning solutions are an important milestone on the way to the smart factory, which consists of AI-based production facilities and logistics...
Optometron
Check unordered objects
Optometron has added the Deep Learning module to its VIS-Vision software. This module identifies and assesses objects that are also randomly present without structure, i.e. regardless of the position, angle, size or illumination of the objects.
