BI tools
Quelle: Industrie Informatik | Lukas Dehling,
Quick and easy design of evaluations
Industrie Informatik presents the operational BI tool Pido, which is integrated into the MES solution cronetwork.
© Industry Informatics
The tool is intended to enable employees to design evaluations quickly and, above all, easily, as the entire nomenclature of the information in the integrated meta-model corresponds 1:1 with that of the programs and processes. This should save the redundant maintenance of external meta-models. According to the manufacturer, there are also advantages such as the integrated MES foundation for release maintenance and internationalization of the solution, as well as an engine that serves different needs. Companies should be able to use the solution to combine classic business functions from their applications with their own information requirements.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
