Current productsNews from the Software & IT sector
Software & IT is also becoming increasingly essential for manufacturing. As a result, numerous products with this focus are coming onto the market - as the following series of images shows:
3 of 15
LTE router MRO-L200 from Insys
© Insys icom
In addition to the certification of the MRO-L200 LTE router from Insys icom, the basic variants (DSL, LTE, LAN) of the MRX modular industrial router series are Microsoft Azure certified for IoT. The routers are pre-tested and verified to work with Microsoft Azure IoT services so that IoT solutions can be implemented quickly. The certified MRX3 and MRX5 router series capture data from a wide range of applications regardless of protocols and manufacturers. Verification of the routers as 'Microsoft Azure Certified for IoT' enables direct coupling with Microsoft Azure projects via MQTT. The MRX router series is based on a fully modular platform. The basic LAN, DSL and LTE variants are available in two housing widths with three or five slots. Expansion cards (MRcards) supplement the basic variants with selected modules such as serial ports, digital I/Os, Ethernet switch, VDSL/ADSL or LTE.
3 of 15
