MES solutions
Quelle: Guardus Solutions | Lukas Dehling,
Graphical test data and fault recording
The company Guardus has updated and expanded its MES solution: The focus is on intuitive applications for mobile action management, graphical inspection/defect data handling and checklist recording.
© Guardus Solutions
One new feature is the intelligent function for mobile, graphical inspection data and defect recording. If the store floor employee discovers a deviation during an inspection during production, they call up the corresponding image from the inspection order and mark the affected item. Guardus MES then automatically sets a graphical visualization, while the user can assign the textual description via a predefined error catalog. Instead of following predefined work steps, users can also use the checklist entry function to work through the inspection steps individually and, above all, on the move and tick them off in a checklist. Additionally stored online documents and drawings provide information on special instructions, while scanning options make it easier to record the product ID.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
