Programming system
Galvanic signal isolation possible
The HTV subsidiary Ertec offers the newly developed Ertius onboard programming system. According to the manufacturer, it enables extremely fast, reliable and efficient programming directly on the production line for high-speed flashing of assemblies.
Up to four programming heads can be reliably controlled via long cables of up to 5 m - with galvanic signal isolation if required. The individual programming processes run autonomously and independently of each other, which enables parallel programming of the same or different device types with identical or different programming data. Project-specific customer requirements such as serial number programming, restoring and modifying sample-specific production data or setting up write and read protection should be easy to implement thanks to the flexible structure.
