Production software
Quelle: Rockwell Automation | Lukas Dehling,
Fast access to production data
Rockwell Automation is expanding its EMI software (Enterprise Manufacturing Intelligence) Factorytalk Vantagepoint in version 7.0 with functions for easier configuration.
© Rockwell Automation
This should speed up access to large amounts of data, as manufacturing intelligence solutions only need to be configured and imported once. The new version offers users direct access to Logix-based data. The information is saved and displayed using an intuitive workflow wizard. Processes such as installation, configuration and display have been standardized, according to the manufacturer. This should enable users to view and evaluate their Logix-based data on the device of their choice, such as a PC, tablet or smartphone. The workflow wizard can also be used to share certain data views and trends with other employees across the company. In addition, Factorytalk Vantagepoint now also automatically installs Factorytalk Historian SE software. This gives users access to the Vantagepoint mobile website with new import and configuration options.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
