ERP systems
Quelle: Delta Bart Systemhaus | Lukas Dehling,
Combined with production and maintenance
Delta Barth presents Deleco 6.35, a business software that combines ERP, merchandise management, production planning and maintenance management.
© Delta Barth System House
A new user interface displays the production order and the object master data side by side. With a click of the mouse, the user decides which elements of the material list should be displayed in the maintenance object. Additional information can also be viewed in this way: the spare or wear parts used in the object, the history of the system including the serial numbers of all components and the reference to the production order itself, for the traceability of all components. The new fault reporting portal can access the portal's web interface on any PC in the company via the company's own intranet - no software installation is required. The fault reporting portal can also be accessed via terminals and a corresponding app. The app is available for iOS, Android and Windows Phone. Data transmission is SSL-encrypted.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
