Horner Automation at the SPS 2023
Versatile, modular I/O system
'OCS-I/O' is a compact, expandable I/O system to supplement the PLC controllers from Horner Automation. The system can be used both as a local extension and decentralized.
© Horner
The 'CNX116' base module from Horner Automation has two variable inputs (digital or 12-bit analog), two digital outputs, a 16-bit universal analog input and a 12-bit analog output. This means that up to three analog inputs are available without the need for an additional module. The I/O system can use up to seven modules per base and 16 bases per network. Each base has a CsCAN input and output, so that several bases can be connected in series without any wiring effort. The device is easy to integrate. The free 'Cscape' software from Horner is used for project planning. After networking, the base is automatically found and all installed modules are configured.
Bihl+Wiedemann
Innovation partner for automation
Bihl+Wiedemann is a medium-sized, owner-managed company - founded in 1992 by Jochen Bihl and Bernhard Wiedemann in Mannheim. It develops and manufactures complete solutions for functional safety and data communication in machines and systems.
Weidmüller
Joachim Herz Foundation invests
The Hamburg-based Joachim Herz Foundation acquires a stake in Weidmüller as part of a capital increase and thus holds around 20% of the shares in the family-owned company. The commitment is aimed at long-term corporate development and accelerated...
