Controls
Quelle: Ininet Solutions | Inka Krischke,
Programming via web browser
Until now, programming a PLC required a PC application that had to be installed for the respective product.
© iniNet Solutions
SpiderPLC from Ininet Solutions, on the other hand, only requires an HTML5-capable browser and a controller equipped with the "SpiderPLC" for programming. This consists of a PLC runtime, a web server and an integrated web application that enables the function block diagram programming of the PLC and associated HMI pages. All the software required for programming and operating simple PLC projects, including visualization, is stored on the embedded controller. This means that only a tablet, smartphone or PC with a standard web browser is required for programming. "SpiderPLC" allows the PLC to be programmed in the 'function block diagram' programming language. In addition to function block diagram programming, there is also an HMI editor that enables the design of simple HTML5-compatible visualizations. In addition to use on simple low-cost controllers, the solution is suitable for integration into existing electronic devices that are to be expanded with a simple programming option in addition to the existing functionality. This includes, for example, systems such as data loggers, measuring devices, controllers, intelligent sensors, drives or gateways.
Delta Logic
Update brings support for TIA V19
Delta Logic has updated the 'Accon OPC UA Server' software to version 1.4.0.0. The new features include support for TIA Portal projects of version V19 and for the latest firmware for CPUs of the Siemens S7-1200 and S7-1500 controllers.
Cooperation
RoboDK and Keba work together
RoboDK and Keba Industrial Automation have announced their collaboration. Together, they want to simplify the life cycle of a process solution with integrated robotics - from quotation preparation to after-sales support.
