Gateways
Quelle: Softing | Inka Krischke,
Migration from OPC Classic to OPC UA
The current version 4.10 of Softing's Datafeed OPC Suite provides OPC UA client functionality and can be used in various OPC UA gateway solutions.
© Softing
Controllers with an integrated OPC UA server, such as controllers from B&R, Beckhoff or the RFID reader from Harting, can be easily integrated into existing OPC Classic environments. According to the manufacturer, this allows users to implement Industry 4.0 solutions step by step using their existing OPC Classic components. This version provides customers with a solution for easy migration from OPC Classic to OPC UA. The software also offers logger functionality for OPC UA servers, which can be used to save process data from a controller with an integrated OPC UA server to a file or database. Thanks to the OPC UA client functionality, the tool not only acts as a gateway between OPC Classic and OPC UA applications, but also as a central gateway between several OPC UA servers and clients. The OPC UA clients only need to connect to one OPC UA server or only one aggregated OPC UA address space needs to be managed.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
Security
Protect critical systems
IT security is mainly concerned with data, while Operational Technology (OT) is primarily concerned with machines and systems, with the focus here being on the safety of people, the environment, quality and performance.
