Kendrion Kuhnke Automation
Individually expandable
Vico PLC is a PLC with touch display from Kendrion that has been designed for use in automatic machines, machines or machine parts as well as in building automation.
All the necessary functions for visualization, control and various communication options are integrated into the basic device and can be individually expanded as required. The all-in-one controller is based on the Codesys V3 Development System standard, which is available free of charge, as well as OPC UA. In addition to various communication interfaces such as Ethercat or Modbus, the device can also use a W-LAN adapter, according to the provider. The 'Web Visu' or 'VNC for Remote Desktop' support additional visualizations, diagnostics and service operations. The lightweight, robust plastic housing with UL approval has a fully bonded and therefore seamless touch display with protection class IP66 on the front. The 4, 7 or 10 inch display devices are operated in portrait or landscape format, depending on the application.
