Controls
Quelle: 3S-Smart Software Solutions | Lukas Dehling,
Increasing execution speed
Manufacturers of automation devices can now offer their customers the functionality to manually distribute the various tasks of the PLC application to symmetrical processor cores of the control CPU in Codesys.
© 3S-Smart Software Solutions
Parallel processing increases the execution speed while at the same time utilizing the available processor power - and the user retains control over the timing. Although controllers with operating systems such as Linux or Windows perform such a distribution themselves, the resulting time behavior is difficult to estimate in individual cases. To use the multicore implementation implemented in Codesys, in the simplest case the user simply assigns the desired CPU core to task groups of his PLC application. Available coding guidelines help with more complex configurations. At the same time, the problem of data consistency in data storage or access is solved by appropriate software in the control runtime system, for example to prevent frequent blockages by multiple readers/single writers or to enable atomic access to data types up to 64 bits. With multicore support, complex PLC logic, for example, can be divided into various independent task groups and CPU cores. In addition, the logic application can be separated from the communication and additional functions such as motion, CNC or visualization.
Starter kit
Entry into the IoT
A starter kit from Inonet, together with a web application, is designed to pave the way for users to enter the future of the Internet of Things (IoT). The target group are users who want to monitor their environment automatically and initiate...
Software
Developing autonomous systems
MathWorks introduces the Sensor Fusion and Tracking Toolbox, available with the 2018b release. The new toolbox provides engineers with algorithms and tools to determine and maintain position, orientation and situational awareness.
Gateways
Available with Azure IoT Edge
Moxa's IIoT Edge Gateway is available with Microsoft Azure IoT Edge pre-installed. According to the manufacturer, it offers Azure users a user-friendly solution to expand their IT infrastructure and enable OT data connectivity with their industrial...
Boards
Image processing in focus
The LV-67X industrial mini-ITX board from Spectra is designed for image processing solutions. The integrated LGA1151 socket works with the latest Coffee Lake, Celeron and Pentium CPUs.
