SPS IPC Drives 2016New products in Nuremberg
What new products did the exhibitors present at SPS IPC Drives 2016? Computer&AUTOMATION provides an overview of what was on show in the Nuremberg exhibition halls this year.
64 of 65
Panel PCs of the varioline series from TL Electronic
© TL Electronic
The 48 mm flat panel PCs from TL Electronic's Varioline series with PCAP multi-touch technology are based on Intel's latest NUC (Next Unit of Computing) technology. The 10.16 × 10.16 cm small-form-factor mainboard with the energy-saving fifth-generation Core i5 processor 5300U (Broadwell) is equipped with 4 to 16 GB of RAM and solid-state drives from 64 GB as required. The rear mounting interface can be snapped into the Quicklock box without any tools for mounting or removal. This is firmly connected via a VESA interface to a mounting set for stand or support arm installation, in which the cable routing for power supply, USB and Gigabit Ethernet is integrated. Users can choose between display diagonals from 38.1 cm (15 inches) to 48.3 cm (19 inches) in 4:3 format with a maximum resolution of 1280 × 1024 pixels and from 54.6 to 61 cm (21.5 to 24 inches) in full HD resolution with 1920 × 1080 pixels in 16:9 widescreen format. The devices operate without a fan and offer IP65 protection.
64 of 65
