SPS IPC Drives 2016New products in Nuremberg
What new products did the exhibitors present at SPS IPC Drives 2016? Computer&AUTOMATION provides an overview of what was on show in the Nuremberg exhibition halls this year.
56 of 65
7_New measuring case from Delphin Technology
© Delphin Technology
Based on the Expert Logger high-speed data logger series, Delphin Technology offers a measuring case that combines two applications: On the one hand, it can record, balance and store energy consumption; on the other hand, it can be used to analyze faults in machines and process signals. The mobile measuring case is available in different configuration levels. For energy monitoring applications, the case can be equipped with up to three independent measuring circuits for power measurement. This means that the energy consumption of several machines can be recorded simultaneously. Eight synchronous digital/frequency inputs can be used to record energy meters or flow rates, while up to 46 analog inputs and 48 digital inputs can be used for fault analysis. The sampling rates range from 20 µs to hourly or daily averages. All measured values and energy consumption can be stored independently - the internal data memory offers space for around 500 million measured values. The measuring case also has an OPC UA interface and can transfer measured values directly to the cloud.
56 of 65
