SPS IPC Drives 2016New products in Nuremberg
What new products did the exhibitors present at SPS IPC Drives 2016? Computer&AUTOMATION provides an overview of what was on show in the Nuremberg exhibition halls this year.
51 of 65
18_Terminal blocks and process-supporting services from Weidmüller Interface
© Weidmüller Interface
Klippon Connect is the name of Weidmüller's terminal blocks and process-supporting services, which are designed to save up to 75% of engineering time, ensure error-free wiring at all times and speed up marking processes. Two terminal block programs are available - an application program and a universal program. Which range is the most suitable choice depends on the respective requirements. The universal program is designed to be function-oriented. For frequently recurring applications, such as control current distribution or signal wiring, the application program is ideal, in which product functions are specifically arranged or omitted. The application also determines the respective connection technology, screw or spring connection. The screw connection is designed as a clamping yoke or bolt connection, the spring connection in push-in or tension clamp technology. The 'Weidmüller Configurator' (WMC) is available for designing the planning process. The web-based software solution provides step-by-step support for selecting and assembling terminal blocks and accessories. The integrated plausibility check ensures only permissible configurations - any errors are automatically corrected.
51 of 65
