Control 201630th anniversary of the trade fair
Over 900 exhibitors from 32 countries are expected at Control from April 26 to 29, 2016. The world's leading trade fair for quality assurance is celebrating its 30th anniversary this year.
Isra Vision is presenting a sensor that combines triangulation, stereometry and phase-shifting fringe projection to bridge the gap between 3D shape detection and dimensional accuracy testing. Thanks to its stereometric design with two cameras, the sensor uses triangulation to map the surface properties of the test object in three dimensions. Depending on the setting, it uses a striped or random pattern for illumination. With fringe projection, a temporal sequence of parallel line patterns with different brightness values is projected onto the object. The cameras record the images of the modulated brightness distributions at the known angle of view (triangulation angle) and pass them on to an algorithm that can calculate the object coordinates from them. By projecting the fringe pattern via a micromirror array, the line patterns can be adapted and executed at high projection speed, according to the manufacturer. By using a sinusoidal pattern for the phase shift, the sensor also only requires around two thirds of the image recordings that would otherwise be necessary when using a conventional gray code pattern. An LED with high luminosity ensures that sufficient light is returned to the cameras.
