Control 201630th anniversary of the trade fair
Over 900 exhibitors from 32 countries are expected at Control from April 26 to 29, 2016. The world's leading trade fair for quality assurance is celebrating its 30th anniversary this year.
7 of 13
Laser profile scanner Scancontrol 29xx-10/BL from Micro-Epsilon
© Micro-Epsilon
The Scancontrol 29xx-10/BL laser profile scanner from Micro-Epsilon is equipped with a blue-violet laser diode and projects a laser line just 10 mm long onto the measurement object with a profile resolution of 1280 points. This results in a point spacing of just 7.8 µm, which, according to the manufacturer, means that this laser profile scanner has more than twice the resolution of previous laser scanners with a 25 mm measuring range. Compared to the red laser, the blue laser line can be imaged much more sharply; the light does not penetrate the object being measured and is much more stable. This means that glowing and organic objects can be measured more reliably.
7 of 13
