Block I/O modules
Quelle: Hans Turck | Inka Krischke,
Functionally expanded
Turck is expanding the functionalities of the TBEN-S-RFID Ethernet/RFID interfaces. A free firmware update is available for the block I/O modules with IP67 protection, which offers functions such as the license-free 'Argee' programming environment.
© Hans Turck
With this field logic controller (FLC) function, users have the option of executing small to medium-sized control tasks directly on the block I/O module and thus outsourcing them decentrally. This reduces the load on the controller and enables only relevant data to be transferred. The block I/O module can be connected to PLC systems without a special function block. Another new feature is the automatic addressing of the bus-compatible HF RFID read/write heads by simply activating the read/write head addresses in the parameters of the data interface. This saves users time compared to conventional methods, as they can connect the read/write heads one after the other and address them automatically. In addition, bus addresses for bus-capable HF read/write heads can be set and queried via the block I/O module using the web server/pactware. This allows users to quickly check the correct commissioning of the bus mode without using an interface converter.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
