HMI controls
Quelle: Hans Turck | Lukas Dehling,
Control, operate and monitor
The TX500 HMI controllers from Turck have been designed for use in small to medium-sized machines whose processes need to be controlled, operated and monitored on site.
© Hans Turck
Each device has a Profinet master, Ethernet/IP scanner and a Modbus TCP and Modbus RTU master. With the two Modbus protocols, the HMIs can also be operated as slaves. Codesys3 is designed to allow lean and simple programming of the control and visualization functions. Thanks to the high-resolution TFT display with 64,000 colors, graphics and animations are displayed attractively and with high performance, according to the manufacturer. The front of the TX500 series complies with protection class IP66. On the connection side, two RJ45 Ethernet ports, a serial interface for RS232 or RS485 and two USB ports are available. An additional SD card slot allows the internal data memory of 128 MByte to be expanded. Turck offers three variants of the TX500 series, which differ in display size and resolution: two 16:9 displays with 7 or 13 inches (TX507 and TX513) and a 10-inch device in 4:3 format (TX510). The two smaller displays offer 800 × 400 pixels, while the TX513 variant has a resolution of 1280 × 800 pixels.
Turck
Paving the way for digital transformation
Automation solutions from Turck support the profitability, efficiency and sustainability of machines and systems. In this way, they not only increase competitiveness, but also contribute to more environmentally friendly production and intralogistics.
Review
The top articles in June 2023
Interest in the topic of artificial intelligence continues unabated and is also reflected in our most-read article of the month of June: two youngsters who have set out to overcome fears of AI technologies lead the ranking. The top 10 at a glance.
Turck
Multitool for the IIoT
With the IIoT platform 'TAS', Turck promises an easy-to-use and standardized overall solution for the commissioning and management of Turck devices in industrial Ethernet networks, from the sensor to the controller. The tool celebrated its premiere...
