Chassis
Quelle: Comp-Mall | Lukas Dehling,
Wall or switch cabinet mounting possible
With the EBC-2200 embedded chassis, Comp-Mall offers a housing unit for Epic single-board computers. The chassis is designed to facilitate the construction of an embedded system.
© Comp-Mall
The chassis is specially designed for the SBCs NANO-BT-i1 with on-board Intel Bay Trail SOC Celeron J1900 and model NANO-QM871 with Intel mobile Core i7-4700EQ and QM87. The low power consumption of the Bay Trail models results in fan-free operation and a temperature range of -20 to 60 °C. The variant is available with a maximum of 8 GByte 1066/1333 MHz DDR3L SDRAM. Two displays - VGA and HDMI - have externally accessible connections. The following interfaces are available: 2 x GLAN and optional WLAN 802.11b/g/n, 3 x USB 2.0, 1 x USB 3.0, 3 x COM, VGA, HDMI and audio. SATA with 3GByte/s, a drive bay for 2.5-inch HDD/SSD, an internal PCIe mini card connector and a PCI-104 slot for expansions round off the functionality. A watchdog timer between 1 and 255 s allows a programmable restart. The SBC NANO-BT-i1 supports the IEI Remote Intelligent System (iRIS). A 12 V(DC) power supply is required, an optional mains adapter is available. Mounting brackets and VESA 100 allow mounting on the wall or in a control cabinet. The dimensions of the metal housing are 215 mm x 150 mm x 55 mm.
Wöhr
Two new surface-mounted keyboards
Wöhr is expanding its 'Surta' industrial keyboards with versions 15 and 16, which have been specially developed for environments such as medical and dental areas, the pharmaceutical, clean room and food industries, as well as general industry and...
Siemens
Edge rack server in robust
The trend towards hyper-convergent infrastructures is not stopping at the manufacturing and automation industry. Siemens has now launched the first edge rack server in robust industrial PC quality. How is the inner workings of the server designed?
