Embedded PCs
Quelle: ICS | Lukas Dehling,
Suitable for vehicle installation
With the Nuvo-5100VTC, Industrial Computer Source presents an embedded PC that is E-Mark and EN-50155-certified and is therefore suitable for installation in vehicles. The devices are equipped with sixth-generation Intel Core i7, i5 and i3 CPUs.
© ICS
A DDR4 RAM can be connected via two SO-DIMM sockets, which can be upgraded with up to 32 GB. The I/O interface resources include 4 × USB 3.0, 4 × USB 2.0, 1 × VGA + DVI-D connector, 2 × DP, 1 × audio. The device is equipped with four 802.3at PoE+ ports, which provide connected devices with up to 25 W of power. The ports are also equipped with M12 connectors, which, according to the manufacturer, ensure a reliable connection in extremely harsh environments. Two Gigabit Ethernet ports are available for data communication. Four internal mini-PCIE sockets can be used for correspondence with 3G/4G/WiFi modules. The Nuvo-5100VTC also offers an integrated CAN bus for internal vehicle communication and an isolated DIO for sensors or other elements. In conjunction with the automatic start and the dual-drive RAID system, the embedded PC meets the requirements for in-vehicle operating conditions.
Logistics systems
New products for Logimat 2019
What is currently happening on the market in the areas of material flow and process management? Computer&AUTOMATION has compiled an excerpt of what exhibitors are showing at the Logimat 2019 logistics trade fair in Stuttgart in a series of...
Box PCs
IoT device for logistics
The new 'Vehicle Computer Compact M8' embedded box PCs from Syslogic have no moving parts, are shock and vibration resistant and are designed for an operating temperature range of -40 to +85 °C.
Tablet PCs
Optional UPS module available
The outdoor tablet PC model 'UPC-F12C-ULT3' from Comp-Mall in an aluminum housing can be used as a mobile or stationary device and is protected against dust and splash water thanks to its all-round IP65/IP66 protection class.
Control units
Freely programmable
The ESX-4CS-GW is the first product in the fourth generation of control units from Sensor-Technik Wiedemann. As a communication gateway, it offers six CAN interfaces, a 4-port Ethernet switch, a LIN and an RS232 interface.
