Memory cards
Quelle: Rutronik | Lukas Dehling,
Sequential data rates of up to 90 MByte/s
Swissbit's S-450 and S450µ SD memory card models are based on SLC flash technology and a system and firmware architecture with features to maximize data retention and security.
© Swissbit
Thanks to intelligent firmware algorithms, such as intelligent read-disturb management and the autonomous, performance-neutral background process 'Auto Refresh', data retention is up to 100 times higher than with conventional solutions, according to the manufacturer. In the event of an unforeseen power failure, the firmware prevents data loss by restoring data using a transaction log. The memory cards are suitable for applications that need to write large amounts of data to small removable media and store it for long periods of time - for example as a system partition of embedded boards, for data acquisition in remote areas or as an intermediate buffer for data transmission.
The SD cards comply with UHS-I bus mode (class 10) and achieve sequential data rates of up to 90 MByte/s for read access and 75 MByte/s for write access. According to the manufacturer, they function in both commercial (0 °C to +70 °C) and industrial temperature ranges (-40 °C to +85 °C) as well as in harsh environmental conditions.
Starter kit
Entry into the IoT
A starter kit from Inonet, together with a web application, is designed to pave the way for users to enter the future of the Internet of Things (IoT). The target group are users who want to monitor their environment automatically and initiate...
Software
Developing autonomous systems
MathWorks introduces the Sensor Fusion and Tracking Toolbox, available with the 2018b release. The new toolbox provides engineers with algorithms and tools to determine and maintain position, orientation and situational awareness.
Gateways
Available with Azure IoT Edge
Moxa's IIoT Edge Gateway is available with Microsoft Azure IoT Edge pre-installed. According to the manufacturer, it offers Azure users a user-friendly solution to expand their IT infrastructure and enable OT data connectivity with their industrial...
Boards
Image processing in focus
The LV-67X industrial mini-ITX board from Spectra is designed for image processing solutions. The integrated LGA1151 socket works with the latest Coffee Lake, Celeron and Pentium CPUs.
