Farnell
Andrea Gillhuber,
Raspberry Pi 5 now in stock
Developers, hobbyists and makers can now order the Raspberry Pi 5 in 4 and 8 GB versions from Farnell. It will be shipped on the same working day.
© Farnell
The new board features an Arm Cortex-A76 quad-core CPU (2.4 GHz, 64-bit) with 512 kB L2 cache and 2 MB shared L3 cache, as well as integrated dual-band Wi-Fi and Bluetooth 5 connectivity. The RP1 I/O controller chip, developed directly at Raspberry Pi, offers a significant improvement in interface performance. These improvements enable a greatly expanded range of applications, says Farnell.
There are also a number of new accessories for the Raspberry Pi 5, including a case with an integrated variable speed fan. If you want to use the Raspberry Pi 5 under high load without a housing, an active cooler offers an alternative cooling solution. A new USB-C PD power supply (27 W) delivers up to 5 A current at 5.1 V, so that the Raspberry Pi 5 can also supply peripheral devices with power.
Avnet
New president at Farnell
Avnet has appointed Rebeca Obregon as the new President of Farnell, an Avnet company, effective July 1, 2024. Farnell is a high-service distributor of electronic components.
