Boards
Quelle: SSV Software Systems | Lukas Dehling,
Pre-installed machine learning algorithms
With the DNP/AISS1, SSV is presenting an evaluation board with various sensors and pre-installed machine learning algorithms for industrial applications.
© SSV Software Systems
The aim is to create applications that convert sensor data into information using classification or regression, for example. The board includes a Docker container. This contains preconfigured and ready-to-use development tools for the training phase and modeling. A webinar is also offered to all board users. According to SSV, traditional firmware development for embedded systems is time-consuming and relatively inflexible over the entire product life cycle, which is why the company is taking a new approach: An adaptive algorithm with artificial intelligence (AI) is inserted between the input and output data of a microcomputer and configured for a specific task using special training data. This creates a mathematical model that maps the respective relationship between the inputs and outputs.
Product presentations
Collect and analyze data
What options for IoT connectivity are currently available in the manufacturing and industrial environment to implement big data applications? Computer&AUTOMATION has compiled a selection of current products from this area in a series of images.
Box PCs
Predestined for AI applications
The CamCollect 8208 and CamCollect 7164 box PC product series from Aprotech are supplied complete with an operating system so that AI applications such as Microsoft Azure or Amazon AWS can be installed directly.
SSV
AI-based Continuous Monitoring
Each connected module now includes integrated AI functions: while this is standard in today’s smartphones, it remains rare in automation. Yet, such AI could serve as a foundation to detect communication issues caused by cyberattacks in real time.
Avoid crowdstrike errors
The cyber security of networked applications can be improved with the help of automatic attack detection systems or intrusion detection systems (IDS). However, as the Crowdstrike incident makes clear, an IDS is only suitable for use in industrial...
