Efco Electronics
Industrial PCs for the control cabinet
Efco Electronics has added two new industrial computers to its range that are designed for direct mounting on the DIN rail. All connections of the IPCs, which are based on the 'Eagle Eyes' platform, are located on the front of the device.
While the high-end version 'AIHD' is primarily designed for demanding vision applications, the smaller version 'AIMD' is aimed at HMI and industrial automation. Both models offer 16 digital IOs and an extended temperature range of -25 to +50° C; optionally up to +70° C. All connections, access to the backup battery for the real-time clock and to the hard disk slot are located on the front of the industrial PCs. As the cabling is purely from the front, the computers can be easily installed on the top-hat rail. The design is fanless; the side parts of the housing made of a special aluminum alloy function as additional heat sinks. Equipped with a wide-range input, the top-hat rail IPCs from Efco Electronics can cope with supply voltages from 9 to 36 V(DC). The integrated overvoltage protection protects the computers from interference pulses on the supply network.
