Embedded systemsNew products at embedded world 2018
From February 27 to March 1, 2018, the Nuremberg exhibition halls made room for everything to do with embedded systems technology. Computer&AUTOMATION presents a selection of new products that were on show at the stands of the 16th embedded world.
The HTV subsidiary Ertec offers the newly developed Ertius onboard programming system. According to the manufacturer, it enables extremely fast, reliable and efficient programming directly in the production line for high-speed flashing of assemblies. Up to four programming heads can be reliably controlled via long cables of up to 5 m - with galvanic signal isolation if required. The individual programming processes run autonomously and independently of each other, which enables parallel programming of the same or different component types with identical or different programming data. Project-specific customer requirements such as serial number programming, restoring and modifying sample-specific production data or setting up write and read protection should be easy to implement thanks to the flexible structure.
