ICP Germany
For demanding industrial applications
ICP Germany launches the PH14ADI-Q670-12V Mini-ITX board, a solution for AI applications, vision automation, CAD and control as well as industrial applications.
The board is equipped with the Intel Q670 chipset and supports Intel vPro technology. With this platform, users can benefit from advanced security and management features to make the most of embedded applications. Like the 'PH14ADI-H610-12V', the board from ICP Germany has two DDR4 SO-DIMM slots, which enable a maximum memory capacity of 64 Gbyte and thus ensure fast data processing of CAD applications or 4K video editing, for example. The output of graphics via two DisplayPort interfaces is also supported so that two screens can be used simultaneously. An M.2 2280M key slot for NVMe and SATA drives is available for mass storage. A PCIe X16 Gen 4 slot is also available for expansion. For fast data transfer and a reliable network connection, there are two Intel controllers with 2.5 Mini-ITX board Gigabit Ethernet LAN and Gigabit Ethernet LAN.
