Solution package
Quelle: Janz Tec | Lukas Dehling,
Flexible access
Janz Tec offers the MDE:connect hardware-software solution package for flexible machine data acquisition in digitalized production.
© Janz Tec
The availability of process data should make it possible to implement applications such as control stations, big data analytics, predictive maintenance or KPI monitoring. Janz Tec is implementing the necessary solution for the protocol-independent connection of heterogeneous industrial controllers together with its partner verlinked, which is the software provider of the integrated connect gateway. This connect gateway turns the Janz Tec systems into interpreters in the Industry 4.0 world. Whether from CAN to OPC-UA or from Profinet to MQTT: every translation task can be configured via a web-based interface. As soon as a package arrives in one format, the IoT gateway automatically translates it into the required format. According to the manufacturer, future changes can be made with just a few mouse clicks. With CAN, OPC-UA, S7Com, MODBUS and others, the software already supports a large number of industry-relevant interfaces.
Starter kit
Entry into the IoT
A starter kit from Inonet, together with a web application, is designed to pave the way for users to enter the future of the Internet of Things (IoT). The target group are users who want to monitor their environment automatically and initiate...
Software
Developing autonomous systems
MathWorks introduces the Sensor Fusion and Tracking Toolbox, available with the 2018b release. The new toolbox provides engineers with algorithms and tools to determine and maintain position, orientation and situational awareness.
Gateways
Available with Azure IoT Edge
Moxa's IIoT Edge Gateway is available with Microsoft Azure IoT Edge pre-installed. According to the manufacturer, it offers Azure users a user-friendly solution to expand their IT infrastructure and enable OT data connectivity with their industrial...
Boards
Image processing in focus
The LV-67X industrial mini-ITX board from Spectra is designed for image processing solutions. The integrated LGA1151 socket works with the latest Coffee Lake, Celeron and Pentium CPUs.
