Power supply units
Quelle: Bicker Elektronik | Lukas Dehling,
Efficiency of up to 91 %
With the new BEH-530H industrial PC power supply unit, Bicker Elektronik presents a flex ATX power supply unit with 300 W output for powering current mainboards. The IPC power supply unit does not require a base load at the ATX outputs +3.3 V, +5 V, +12 V1, +12 V2, -12 V and +5 V.
© Bicker Electronics
This means that new mainboards with special energy-saving modes (Intel Haswell, Skylake or Kaby Lake processors) can be supplied. Designed for the extended temperature range between -10 and +60 °C, the new power supply impresses with its energy-saving circuit design and particularly quiet operation, according to the manufacturer. The optimum running speed of the ball-bearing fan is infinitely variable depending on the temperature and cooling requirements. The power supply unit achieves an efficiency of up to 91%, meets the requirements for the 80 PLUS Gold certificate and is ErP Lot 6 2013-ready. For international use, the switching power supply has EN/UL 60950-1 safety approvals and a wide-range input 90 to 264 V(AC) - 47 to 63 Hz - with active power factor correction (PFC). In addition to long-term availability of at least five years, Bicker Elektronik offers a three-year device guarantee on the BEH-530H.
Starter kit
Entry into the IoT
A starter kit from Inonet, together with a web application, is designed to pave the way for users to enter the future of the Internet of Things (IoT). The target group are users who want to monitor their environment automatically and initiate...
Software
Developing autonomous systems
MathWorks introduces the Sensor Fusion and Tracking Toolbox, available with the 2018b release. The new toolbox provides engineers with algorithms and tools to determine and maintain position, orientation and situational awareness.
Gateways
Available with Azure IoT Edge
Moxa's IIoT Edge Gateway is available with Microsoft Azure IoT Edge pre-installed. According to the manufacturer, it offers Azure users a user-friendly solution to expand their IT infrastructure and enable OT data connectivity with their industrial...
Boards
Image processing in focus
The LV-67X industrial mini-ITX board from Spectra is designed for image processing solutions. The integrated LGA1151 socket works with the latest Coffee Lake, Celeron and Pentium CPUs.
