Mainboards
Quelle. Fujitsu Technology Solutions | Lukas Dehling,
Continuous operation at up to +50 °C
The Fujitsu D3474-B Thin Mini-ITX motherboard from the Extended Lifecycle series is designed for continuous operation at temperatures up to +50 °C.
© Fujitsu Technology Solutions
According to the manufacturer, this makes the mainboard suitable for tasks in semi-industrial applications such as digital signage, 1U solutions, HMIs or touch panels. However, the mainboard is also suitable for all-in-one PCs (AiO), so-called 'tiny box' PCs and systems with a flat design. It has an LGA1151 CPU socket and supports processors with a TDP of up to 65 W. This includes models from the Intel Core i3, i5 and i7 series of the 6th generation and the current 7th generation. The board can also be equipped with Intel processors from the Pentium and Celeron series. The integrated H110 Express chip set supports up to 32 GByte DDR4-2400 SDRAM. Power is supplied via 12 V(DC) or 19 to 24 V(DC). Hard disks or solid state drives (SSDs) can be connected via SATA III interfaces. An M.2 SSD interface (SATA) is also available for SSDs. Users can also integrate wireless LAN and Bluetooth modules via an M.2 slot. A Gigabit Ethernet port is available for connection to wired networks. There are also interfaces for USB and serial devices with RS232 as well as an 8-bit GPIO port (General Purpose Input/Output).
Starter kit
Entry into the IoT
A starter kit from Inonet, together with a web application, is designed to pave the way for users to enter the future of the Internet of Things (IoT). The target group are users who want to monitor their environment automatically and initiate...
Software
Developing autonomous systems
MathWorks introduces the Sensor Fusion and Tracking Toolbox, available with the 2018b release. The new toolbox provides engineers with algorithms and tools to determine and maintain position, orientation and situational awareness.
Gateways
Available with Azure IoT Edge
Moxa's IIoT Edge Gateway is available with Microsoft Azure IoT Edge pre-installed. According to the manufacturer, it offers Azure users a user-friendly solution to expand their IT infrastructure and enable OT data connectivity with their industrial...
Boards
Image processing in focus
The LV-67X industrial mini-ITX board from Spectra is designed for image processing solutions. The integrated LGA1151 socket works with the latest Coffee Lake, Celeron and Pentium CPUs.
