STV Electronics
Computing platform for the control cabinet?
In the age of digitalization and IIoT, closed systems are being replaced by open, freely programmable edge computing platforms. Solutions based on the Raspberry Pi ecosystem are becoming increasingly attractive for this.
© STV
Building automation has long been a fixed planning component in every new building, in residential buildings as well as factories and all other commercially used functional buildings such as office buildings or shopping centers. The tasks of building automation range from the efficient use of energy in air conditioning, heating, ventilation or lighting technology to security solutions using automated locking technology or visualization via surveillance cameras.
The implementation of such automated building control systems began in functional buildings, with so-called Direct Digital Controls (DDCs) and PLC modules primarily being used at the automation level. These record the information from the sensors at field level, process the data according to their control algorithms in the stored control program and send the results back to the actuators at field level as control commands.
The Raspberry Pi 3 B+-based Smart Manager 4.0 top-hat rail PC for the control cabinet makes it possible to implement even complex tasks in control technology and building automation with open source-based hardware and software.
© STV
This has also led to a variety of proprietary automation solutions within different trades, especially as the transmission systems used at field level often use different media and protocols. If you want to create interoperability between the various building automation technologies, you need a platform that not only provides comprehensive hardware interfaces at field level, but also offers the option of integrating the various systems on the software side, for example to implement needs-based, software-based PLC applications. Current trends - such as digitalization, IIoT and smart metering - make it necessary to connect even individual systems via a dedicated edge computer. It makes it possible to seamlessly connect IP technology with central dashboards as well as management and maintenance clouds. This also enables the integration of suitable edge logic on site. This must be increasingly freely programmable in order to meet the growing demand for smartphone-based control of every building function, for example, or to execute inference logic that is required for predictive maintenance purposes, as it is not possible or desirable to push every measured value into the cloud.
More freedom in building automation
OEMs and system integrators are therefore looking for a solution for building automation that can be integrated into the control cabinet in a flexible and cost-optimized way. One such solution could be platforms based on the new, performance-optimized Raspberry Pi 3 B+. They are equipped with an open-source Linux distribution and can be adapted to specific requirements. This means that there are virtually no restrictions when installing additional software such as development environments or automation applications that are to be used on such edge control centers for building automation and control technology.
But what are the specific advantages of an approach with Raspberry Pi?
From educational object to industrial platform
The interface equipment and the separate expansion bus allow the Smart Manager 4.0 to be used in the control cabinet as an IoT/edge server - both for building automation and industrial control solutions. Even meters in the classic M-Bus field bus can be managed via MQTT using a level converter docked onto the mini PC.
© STV
In 2012, the Raspberry Pi was introduced to the market in its original, first version for educational purposes as a particularly inexpensive yet complete open source development platform. Anyone with an interest in IT hardware - and hardware programming and development in particular - could get started with the low-cost single-board computer almost immediately.
And so it was not long before the devices were increasingly used as a practicable
development platform in the embedded industry, as the Raspberry was a fully-fledged Linux mini-computer that could be used as a development and test platform at the same time.
To date, around 30 million Raspberry Pi devices have been sold, which is also reflected in an impressively large online support community. In the meantime, the Raspberry Pi is well on its way to becoming a new standard industry platform. Oracle, for example, uses a cluster of 1060 Raspberry Pis for the world's largest Pi supercomputer. And NASA's Jet Propulsion Laboratory has published a blueprint that uses a Raspberry Pi as the basis for a replica of the Mars rover. Now the minicomputer is setting out to conquer industrial applications. STV Electronic is one of the first manufacturers to have an industrial-grade version of the minicomputer in its portfolio with the Smart Manager 4.0.
Industrial-grade Raspberry
Version 3 of the Raspberry Pi comes with a BCM2837 SoC from Broadcom, which is made up of a 1.2 GHz quad-core ARM processor with a generously dimensioned visual processing unit (400 MHz). The four Arm Cortex-A53 cores are responsible for the high computing power, enabling the platform to take on even very complex tasks in the IoT/edge area of building automation. The Armv8-A architecture impresses with up to 60% more performance than its Cortex-A7 predecessor. It also offers improved power management for minimal heat generation, meaning that the Smart Manager 4.0 can operate without active ventilation even at extreme temperatures of -40 to +55 °C inside and outside the control cabinet.
In addition to the 1 GB LPDDR2 SDRAM RAM, the STV Smart Manager 4.0 can be ordered with either 8, 16 or 32 GB on-board eMMC flash, providing sufficient storage space for every application. Alternatively, the Smart Manager 4.0 is available as a variant with an SD slot.
The open source-based Raspberry PCs are fully suitable for industrial use. This is because the Smart Manager 4.0 uses SODIMM processor modules specially designed for use in the industrial sector, for which the Raspberry Foundation alone guarantees long-term availability until at least 2026.
In addition to the corresponding planning security, the modular design also offers flexibility and scalability, as the industrial PC can also be expanded on the hardware side with higher-performance CPU modules. STV has therefore set the long-term availability for its industrial PC at ten years, which is another important requirement for electronic components in industrial use.
Interface diversity and flexible installation
Thanks to its shallow installation depth of 62.2 mm, compact width of 6HP (108 mm) and the PC interfaces at the top to the field level and at the bottom, the Raspberry Pi computer 'Smart Manager 4.0' fits into any control cabinet.
© STV
In terms of communication interfaces, the Smart Manager 4.0 offers up to 2x Fast Ethernet, 6x USB 2.0 and two galvanically isolated, terminable serial RS485 interfaces, one of which can also be configured as RS232 on the software side. Additional functionality such as WLAN, fieldbus and further I/O connections can be added via these interfaces as well as an expansion bus for further additional modules if required.
The Raspberry Pi computer 'Smart Manager 4.0' for industrial use.
© STV
For example, the minicomputer can take over the tasks of an M-Bus master by coupling it to a corresponding level converter in the control cabinet. The Smart Manager 4.0 can even be installed in the flush-mounted small distribution boxes of building automation systems in accordance with DIN 43880, which allow installation depths of up to 70 mm, thanks to its very flat top-hat rail housing measuring just 62.2 mm.
Thanks to its very broad power supply range of 12 V to 30 V, the Smart Manager 4.0 can also be connected very flexibly to any existing power source in the control cabinet.
Free program selection
The Raspberry Compute CM3+ is installed in the 'Smart Manager 4.0' as a SODIMM CPU module, which guarantees additional flexibility, scalability and planning security.
© STV
The Smart Manager 4.0 also offers flexibility in the choice of programming, control or automation platforms. For example, STV provides the DIN rail PC ready for use - with a precisely tailored Linux OS, comprehensive software and integration support as well as continuously updated security patches. The system can be programmed and developed with Codesys, NodeRed, Node.js, C, C++ and numerous other environments.
Alternatively, a building automation platform such as FHEM and openHAB can be installed to control the peripherals. The mini PC can be transformed into an MQTT broker with Mosquitto.
Markus Hühn is Managing Director of STV Electronic.
© STV
System integrators benefit from the huge community of Raspberry PI users with countless detailed projects, support and solutions to problems. In this way, they can provide application-ready, industrial-quality solutions based on industry-standard open source solutions for many tasks in building automation and industrial control technology and guarantee their customers a high level of long-term availability.
TTTech
The PLC in the data center
What are the advantages of using an integrated, centralized control architecture on an edge server instead of a large number of individual controllers with their own electronics? Only used in isolated cases today, such an architecture could become...
