Kontron at the SPS 2022
Yvonne Junginger,
Compact and modularly scalable central computer
Kontron presents the KBox R-101 with EN 50155 certification and 5G connectivity.
© Kontron
The control and communication platform in box PC format from Kontron is based on a fanless, passively cooled and IP54-compliant system solution with industry-approved mechanical and electronic components. The system and all external interfaces are suitable for use in harsh industrial environments and public transportation. Based on the eleventh-generation Intel Core i7-1185GRE processor and a maximum memory expansion of 32 GB, the platform supports OEM manufacturers and system integrators in setting up system solutions.
On the front, it has three Gigabit Ethernet interfaces M-12 x-coded, two serial I/Os and a USB-C interface. There are also six cut-outs for antenna connections as well as seven LEDs, which can be used for specific applications, and a power LED. The system is designed for operation in a temperature range between -40 and +70 °C.
SPS 2022: Hall 7, Stand 193
QNAP
Virtualization of network functions
QNAP has introduced the new QuCPE-303x Network Virtualization Premise Equipment. It combines network function virtualization, QuWAN SD-WAN and the AMIZ cloud management platform with Intel hardware network acceleration technologies.
Kontron
Motherboard in Mini-ITX format
Kontron presents the 'K3836-Q/R mITX', a motherboard in a compact mini-ITX format. It is equipped with the latest Intel Core processors of the 12th, 13th and 14th generation and a set of modern interfaces.
Kontron
5G module production entirely in Europe
Kontron has announced that it will manufacture its 5G modules entirely in Europe in future. In doing so, the company wants to underline its commitment to shorter supply chains, Europe's technological sovereignty and the reduction of CO2 emissions.
