Spectra
Building block for AI applications
The MT800 embedded board from Spectra supports 8th generation Intel Core i processors and has 32 Gbytes of system memory.
© Spectra
Current NVDIA MXM GPU cards up to 190 W can be accommodated on the MXM socket. Thanks to the advantages of NVIDIA's GPU technology, parallel processing performance with high energy efficiency is possible.
Four display interfaces (2 x DP, 1 x DVI-D, 1 x x VGA) and expansion options via a fast PCIe x16, a Mini PCIe and an M.2 (M-Key) slot round off the range. The Spectra board offers six USB 3.1 ports and two Gigabit LAN ports specifically for connecting cameras. The embedded board runs both Windows 10 and Linux-Ubuntu operating systems.
Spectra
Powerful edge AI server
With the edge AI server from the PowerBox 500 series, Spectra offers system integrators a configurable, fanless embedded system for industrial image processing applications, among others.
Spectra
HMI and PLC in one
The all-in-one control units of the 'Uni-Stream' series from Spectra combine a touch display and the control unit with numerous combinations of analog and digital inputs and outputs in a compact housing.
