Advantech
Box PC accelerates AI deployment
The EPC-R7200 from Advantech is an NVIDIA Jetson compatible box PC for industrial use. It is intended for AI developers who use modules from the NVIDIA Jetson family, including Jetson Xavier NX, Jetson TX2 NX and Jetson Nano.
© Advantech
Advantech 's box PC is equipped with a carrier board that is fully compatible with the three Jetson module types in terms of form factor and pin configuration. NVIDIA Jetson modules work with the NVIDIA JetPack SDK. JetPack includes the Jetson Linux Driver Package (L4T) with the Ubuntu Linux operating system and CUDA-X. Both solutions are designed to accelerate AI development. The box PC is fully compatible with NVIDIA SDK and enables AI. It also allows AI developers to automatically control I/Os without the need to install additional drivers or configure functions. It supports a wide range of operating temperatures, power consumption and high vibration tolerance (-40 ~ 85 ºC/-40 ~ 185 ºF; 9 ~ 24 VDC; 3.0 Grms). The Box PC also transforms the Jetson family modules into an edge AI system. This in turn helps users to produce prototypes in practice.
