ifm
Robust data distribution
Ifm is launching unmanaged 6-port Ethernet switches that are suitable for TCP/IP-based IIoT applications and all common automation protocols.
© ifm
They support the 10Base-T and 100Base-TX transmission standards. The ports are equipped with M12 connectors, the power supply is also based on M12 connectors; an optional version with 'daisy chain' is available so that several components in the field can be supplied in series. Depending on the version, the switches from ifm fulfill protection class IP67 or IP69K. The devices with the higher degree of protection are equipped with stainless steel sockets and are also suitable for the food industry, for example. The operating temperature range of -25 to +70 °C, the power supply of 8 V to 32 V(DC) and, according to the manufacturer, high shock and vibration resistance also facilitate use for mobile applications, for example in mobile machines. Thanks to the E20 approval, it can also be used outdoors in vehicles.
ifm
Innovation and quality
Measuring, controlling, regulating and evaluating - when it comes to pioneering automation and digitalization technology, the ifm group of companies is the ideal partner.
Tsubaki cable towing
Minimized abrasion
In the gliding operation of cable drag chains, abrasion in gliding operation as well as oscillations and vibrations are part of the status quo. A module mounted on the carrier provides a remedy by quickly and controllably placing the upper run on...
Business figures 2020
Good result for ifm
Despite adverse circumstances, ifm only recorded a slight decline in sales in 2020. The company attributes the year-on-year increase in earnings to a diversified market and industry structure, among other things.
QNAP Systems
Next-Generation Switches
QNAP has announced the new generation of its QSW-M2130 L2 Web-Managed Switch series. It is available in two models—the standard model “QSW-M2130-4C2S24T” and the PoE++-capable model “QSW-M2130P-2C2S26T.”
